DASYLab
Send command to other equipment via NI GPIB cable.
Hello everyone. I have a Keithley 2700 DMM that is connected to the computer via the NI GPIB/USB (IEEE 488.2) cable.
How do I send command to the DMM using the DASYLAB 9.0 IEEE output object to scan 2 DCV channels? Thanks for any form of advises. Appreciate if there could be an example.
(9,366 Views)
Did you see the response to this in the DASYLab forum?
http://chat.advances.net:8080/%7Edasylabnet
--cj
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(9,364 Views)
Hello CJ BUTLER
I have Dasylab 9 with GPIB/USB and Keilthey 6220.
It seems you have got some demands for the same application.
I search some programs examples i can use with Dasylab. It seems that in lower version there had some examples but not any more.
When I send a command, the instrument turns in remote, but just the fact to send a string put it in Remote.
It seems that the USB/GPIB responds, but i don't know where i can check.
Please can you help on this important project for me.
Best regards
Samuel Vabre
University of Toulouse, Chimical Center
Message Edited by Support on 06-15-2009 11:42 AM
(8,878 Views)
This is the example that I created for the Keithley 2700 series meter. I think that most Keithley meters use the same command language, so it's possible that it will work with some modifications. This was created using the NI GPIB controller.
If you have a TCP/IP Ethernet type device, we don't support that directly. It's possible, but not likely, that the ICOMS Input module would work with it. Because most instruments require a program with setup, monitoring, and shut down logic, ICOMS is too simplistic.
I don't have the meter that you are working with, so, it's very difficult to determine how to make it work. Perhaps you could contact your DASYLab reseller for assistance?
(8,870 Views)
Hello CJ BUTLER
Can you send an example program to put my kethley 6220 in remote mode and to leave it this mode.
Best regards
Message Edité par svabre le 07-17-2007 03:49 AM
(8,846 Views)
I don't have access to your device, and, without that, I can't send an example.
(8,826 Views)
