DASYLab
Run Excel & DasyLab together
First thanks alot for your wonderful site & your helps.
I have a problem with DDE & Action Module.
i use DASYlab Version 12.0.0 .
I use DDE as Export & Action Module for one Project.
Problem: Excel does not open automatically when i open Dasylab & i have to open excel for every project manually.
Is there a solution for that?
(5,808 Views)
I found a solution.Smiley Happy
I changed my Parameter.
(5,796 Views)
I'm glad that you figured that out!
One issue will continue to be timing -- that Action may not run before the DDE modules attempt to connect.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(5,787 Views)
yes. That is a other problem for me. Is there any solution?
(5,769 Views)
Accepted by topic author vahid.mirhosseinian
Not with DASYLab 12.
For DASYLab 2016, I have published a script module that will open Excel in the "Start" phase, before the DDE module tries to connect.
See the KB article at kb.mccdaq.com, below.
http://kb.mccdaq.com/KnowledgebaseArticle50571.aspx
(5,762 Views)
