DASYLab
Program not responding when starting the second time.
I am currently only using the DASYLab program to find the temperatures recorded by nine different thermocouple wires.  On the Worksheet window, I can run the program once with everything running perfectly.  If I stop the program and restart it again, it crashes.  If I go into the Layout window and try to run it at all, it will not respond on the first try.  This happens every time and it doesn't matter what measurement timebase I set it to.
(6,043 Views)
To accurately diagnose your problem, we need the following information. If you do not want to publically post it, you may request DASYLab support at www.dasylab.com or www.mccdaq.com, or call Measurement Computing directly (US) at 508-946-5100.
DASYLab level and version, for example, DASYLab Full V12.0.0 (see the Help-Report)
Your DASYLab serial number - if you post, just the last 5 digits
The operating system
The DAQ hardware and the software version of its drivers
The offending worksheet
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,042 Views)
