DASYLab
Need calibr_e.dsh example file
Where can I get the example file calibr_e.dsh?  The link is in section 6.3 of the quickstart, but when I click it, it says cannot be found.  Thanks.
(7,651 Views)
Hi Jmssucla,
Thank you for posting on the National Instruments forums.
Can you tell me what version of DasyLab you are using?  I checked out the latest version and did not see the link you are refering to in the Quick Start.  It's possible that it is a link from an older version than the one that I am using.  If it is not version 9, please let me know and I will look into the version that you are using.
Thank You,
Nick F.
(7,632 Views)
I have many versions of DASYLab installed, and cannot find that file. What version of the software are you using? I might be able to re-create it for you.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,599 Views)
I'm using 8.0
(7,595 Views)
