DASYLab
MC USB-1808 External clock input troubles
I have some troubles with DasyLab V2016 SP1 and USB-1808.
My config:
* Windows 10 64bits
* DasyLab V2016 SP1
* Instacall V6.70
* MCC DasyLab Drivers V14.0.1.721.en
* USB Daq USB-1808
=> Firmware version 1.00
=> FPGA version 1.03
My Request:
* Recording data by an external clock with an encoder sensor (output TTL 5V at 1khz max)
* 2 Analog Inputs (diff mode) clocked by this external clock
* 2 Digital Inputs software clocked
* 2 Digital Ouputs software clocked
* 2 Analog Outputs software clocked
I need to screen and record one analog input value for each pulse of my encoder
I need to survey the digital inputs at fast as possible (security sensor)
I need to activate the digital outputs at fast as possible (in function of the digital inputs state)
I tested the USB-1808:
In external clock mode (ICLKI=+5V and GND=gnd) and i had an error:
USB device Dev2-Ai0
Data overrun - data was lost
DasyLab version V14.0.1.721
DasyLab Driver version V14.1.0.0
DaqDevInfo version 2.9.3.0
Universal Library version 6.7
=> Why I have this error ?
=> Is the 47kO resistor needed ?
=> Which values that i have to set in the USB input hardware measurement setup (i tried different values but still have the pb) ?
Did the error linked to the configuration ?
Can you tell me which configuration i need to apply to hardware settings and measurement ?
What are the resistriction in terms of frequence and block size for AI (in ext clock) ?
What is the difference between ICLKI and OCLKI clock (OCLKI is the copy of the ICLKI) ?
- I tested the digital inputs (DIO0-1=+5V and GND=gnd) => it worked
- I tested the digital outputs (DIO2-3=+V and GND=gnd) => it worked
=> But when an error occurs, the state stay at the actual state, it doesn't switch to lower ?
=> What is the higher frequency that i can fix ?
I thank you for your answer.
Good day
Hugh
(3,417 Views)
Please report this question directly to Measurement Computing. You will get the best support by contacting us directly.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(3,405 Views)
