DASYLab
How to switch between 2 inputs ?
Dasylab offers a switch module with one input and two outputs.
I need the function of two inputs and one output, so that I can choose, which input to use.
Dasylab does not offer such a function. How can I achieve this ?
The only solution I  know is to use the formeleditor with two input variables and a factor,
which is either '1' or '0'.
Any other suggestion ?
regards
Andreas
(6,917 Views)
You're looking for the Time Slice module, in the Data Reduction group.
There's a very good example of this module in the "Waveform Generator" example in the worksheet examples folder.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,916 Views)
