DASYLab
How i can calculate the integral of peak area
I am acquiring a real time signal from UV detector in HPLC system.
do you have any recomendation that how i can calculate the integral of peak area by using DASYLAB
Thank you for your help.
(7,625 Views)
I am sorry for the delay in answering your post. I must have missed it.
Use a trigger module and a relay module to isolate the peak from the rest of the signal, then use the Differentiation/Integration module to compute the area under the curve. Note that it computes from zero.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(7,550 Views)
