DASYLab
How do you create a parabolic function in the formula editor
I'm trying to make a power ramp up and down function for a stepper motor.  I want to use a parabolic function.  The only problem is the motor cannot exceed a certain speed.  In other words I need to have an upper and lower limit also associated with this.
(6,099 Views)
Put a Scaling module after the formula, and use it to limit the upper and lower range.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,098 Views)
