DASYLab
Help with trigger
I'm using DasyLab 7 and trying to do something simple, but I can't
figure out how to make it work.
My data stream consists of many TTL pulses. How do I configure a
module that will filter out the "quick" pulses, and allow pulses of
longer duration to pass through? All the pulses have the same
amplitude (+5).
Thanks in advance.
(7,295 Views)
On May 9, 8:55 am, shy...@gmail.com wrote:
> I'm usingDasyLab7 and trying to do something simple, but I can't
> amplitude (+5).
> Thanks in advance.
Can you use a Time Delay block as a filter? You could delay by
time, samples or blocks so the signal would have to be hi for a
certain duration before energizing the output.
-Bill
(7,292 Views)
