DASYLab
GE Fanuc Addressing??
I'm working with GE Fanuc PLC's for the first time. I'm attempting to take an older GE Fanuc system, and update the HMI that it communicates with which is currently CIMPLICITY Ver. 3.0 Build 300 and I'm upgrading to NI Lookout V5.0.
The I/O Map that was provided to me has and Address scheme similar to this:
ADDR: %R105 ADDR_OFFSET:17
I'm not familiar with this ADDR_OFFSET? Can you describe to me what it is and how I would translate it into something I can use in my software? At first I thought this was a particular bit in that memory location, but the information that I have tells me the R1-R16383 are 16 bit holding registers encoded as unsigned binary integers ranging from 0 - 65535. If this is the case, then the only logical values
in the ADDR_OFFSET column could be 0-15."
(8,417 Views)
Sorry, accidentally posted in the wrong section.
(8,417 Views)
