DASYLab
Frequency staircase
Hello everyone,
I would like to apply a frequency signal to a shaker using dasylab. This works with the hand controller and the generator module. Now I no longer want to set the frequency manually during the measurement, but to implement a frequency staircase.
Can anyone help me with this?
Thank you very much !
(1,758 Views)
Delete your current Generator and replace it with another Generator with frequency modulation enabled. Connect a Coded Switch to the Generator input. Set both modules to use the Driver time base. The A/D in the toolbar will open the Driver panel. Set the frequency high enough to control the frequency settings properly. Set the Coded Switch to have the desired number of switches. Each position will output a voltage. Divide 5.0 volts by the number of switch positions. For example, 5 / 8 switches are 0.625, so set switch one to zero. Set switch two is 0.625, switch three is 1.25, and so on.Attached is my example.
Please post DASYLab questions at https://forum.digilent.com/
Use the **Data Acquisition and data logging** section
Thank you,
Digilent
(1,746 Views)
Many thanks for the quick reply!
The picture shows what my circuit diagram looks like during a measurement. The whole thing also works, but I would like to simplify the evaluation. I don't want to press the buttons on the coded switch manually, but I want Dasylab to increase the frequency by 300 Hz every 30 seconds. Is this possible and with which modules?
Thank you very much!
(1,716 Views)
Use a Control -TTL Pulse Generator tied to an Action module. Configure the pulse generator so that phase one is one second and cycle restart is 300 seconds. This will cause it to generate a one-second pulse every 300 seconds. Set the action module event to "Rising Edge," the Receiver module to the coded switch, and the action to "Next Position." When it gets to the last switch, it resets to zero and continues.
Thank you,
Digilent
(1,708 Views)
Yes, it works! Thanks a lot.
(1,670 Views)
So far it works automatically to control the frequency. At the moment I control the amplitude manually on an amplifier. Is it possible to control the amplitude via dasylab in the same way as the frequency and how?
(1,462 Views)
You're currently using a Generator module with frequency modulation enabled. Replace it with a new Generator module to get the option to have frequency and amplitude modulation.
Thank you,
Digilent
(1,455 Views)
