DASYLab
Dasylab
I am using Dasylab 12 interfaced with a Datataker DT80 using an Ethernet crossover cable. From the Dasylab Icom library, I am reading an ASCII string that I parse into seperate channels. One of the channel reads a hardware switch, but when I send DT80 program from Dasylab Icom 'Send' command, the initial reading temporarily (about 5 seconds) reads the switch as having its contacts closed which is not the case. I originally thought the issue had to do with the DT80, but that is not the case.
Thank you,
Richard
(6,187 Views)
What does the string look like before it is parsed, and what does the parsed value look like?
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,179 Views)
I have manage to resolve my issue by inserting a time base and an AND gate with my incorrect boolean input.
Thank you,
Richard
(6,139 Views)
