DASYLab
Dasylab Basic Stop Start
Is there a way to automatically start (run) again a worksheet once a stop condition has been triggered?  I see online of method 3 but not sure if applies to Dasylab basic version.
Method 3: Using a Combi Trigger
If the stop command is generated by a data threshold rather than a manual button press:
  1. Use a Combi Trigger module (under Trigger Functions) to define the specific data condition that acts as a "stop" signal.
  2. Connect the trigger output to an Action module or a Relay to trigger actions upon the cessation of data flow
Message 1 of 9
(701 Views)
Or run the sheet again after a certain time period (Looping) continuously.
Message 2 of 9
(700 Views)
Use the Time Control feature located on the Measurement menu.
Please post DASYLab questions at https://forum.digilent.com/
Use the **Data Acquisition and data logging** section
Thank you,
Digilent
Message 3 of 9
(694 Views)
Thank you that worked.  I'll use the other forum.  But one more question.  I use a counter to keep a count.  But it resets and start over again.  Anyway to resolve this from resetting?
Message 4 of 9
(676 Views)
The default setting for the Counter is Cumulative, meaning it continuously counts up. You can clear the count using an Action module.
Thank you,
Digilent
Message 5 of 9
(642 Views)
Not an issue with clearing the count.  It the issue of trying to keep it from clearing while using the time control to cycle through the start stop.
Message 6 of 9
(633 Views)
Write the count to a variable. Use a second variable to hold the last count. Use an Action module to add the count variable to the last count variable when the measurement stops. The Action module can also increment a variable if you are counting how many times the worksheet runs. Review the attached DASYLab 2024 worksheet to see what I mean.
Thank you,
Digilent
Message 7 of 9
(624 Views)
I don't have the action module.  Using DASYlab basic.
Message 8 of 9
(617 Views)
Anyways to keep a running count while using the Time Control in DASYLab basic version?  I'm using a counter, but it resets every time the program cycles between stop and start.
Message 9 of 9
(484 Views)
