11-24-2019 06:32 AM
I want to know if i can manage the communication between DasyLab & CANopen or EtherCAT hardware ?
I want to use : Servo Drive, AC drive AxN, http://www.phase.eu/axn/
or Servo Motors With Electronics, http://www.phase.eu/servo-motors-with-electronics/
If yes, with what hardware & how under DasyLab ?
Good day, Thank you.
Hughus
Solved! Go to Solution.
11-25-2019 07:45 AM
No, this is not possible using DASYLab
CANopen is a higher-level protocol that uses the “normal” CAN as transport protocol (similar: HTML (high) vs TCP (low)).
In the DASYLab CAN modules we can only address specific parts of a CAN telegram directly, we cannot (re-)combine information across several telegrams.
EtherCAT. No direct interface available, perhaps via OPC server. We have no experience combining DASYLab with Beckhoff/EtherCAT hardware.
