DASYLab
Cycle/Loop Set up For DasyLab 2016
Hello, new to this forum. Hope to get some helps here.
Current system:
  • Software: DasyLab 2016
  • Hardware: Omega 2416
I am currently trying to set up a system using Digital Output function and a On/Off switch.
Here is what I am trying to achieve:
  • Automatically cycle On/Off at given cycles (i.e. set for 10 cycles and the switch should automatically be On/Off 10 times
  • Able to read how many cycles it has turned On/Off (i.e if the program has been turned on/off 10 times, a digital display should show "10".)
Any suggestion on which functions I can use to achieve this task is helpful. If you need more information or clarification, please let me know.
(3,389 Views)
I hope that our sales and support at Measurement Computing was able to respond to your question.
There are two good ways to do this -- Use the State Machine in DASYLab Full or the Sequence Generator in DASYLab Pro.
The Statistics--Counter module allows you to count edges and the Action module allows you to control other parts of the worksheet when it detects the defined event -- for example, reset the Counter module when you're done.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(3,317 Views)
