DASYLab
Coded Switch
Hello everyone
Im currently trying to make my finishing touch on my setup, and atm im using 2 coded switches to controll 2 digital outputs with 2 on/off bottons.
The 2 digital outputs controlls my brake, first output is my "close" brake and my second output is my "open" brake.
So my question is, is their anyway that i could make those 2 switches into one on/off bottom?
To clarify what i mean is that instead of 2 bottoms i need one that controlls both outputs, so when i press "on" it will open my brake, by sending "5[V]" to the output and 0 to my other output, and ofcause the other way around as well.
So is this possible to combine into "one switch" ?
regards
The student
(3,681 Views)
Hi, I'm sorry for the long delay.
You can make the Switch into one Switch module, and configure it so that only one is on at a time. See the setting below.
If you want both off, you may need to create a third channel that you don't use.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(3,650 Views)
