DASYLab
Average Time Synchronization
Ìsìt possible to analyze data signals with DL11 by Average Time Synchronization method. E.g vibration signal synchronize with rotation trigger.
(6,165 Views)
Not really. DASYLab is time based, not rotation based.
You could use the index of the rotation to trigger and use the triggered data (via relay) to reset the average. This is something that will require some experimentation to find settings that work for your data.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,149 Views)
Yes, it's possible.
 Use a coder attached to your rotating system (512, 1024 or more points per rev) and connect it to the external analog input clock pin of your data acquisition card instead of internal clock (time based).
Configure your hardware for this operation.
Start Dasylab with FFT's and all interesting modules. You can do order tracking, bearings analysis and all other interesting things that you can find in the Pro version.
Have a good fun!
Frédéric Miqueau
MD Electronic, France
http://www.mdelectronic.fr
French Dasylab Forum : http://www.dasylab-forum.de/forum/index.php?showforum=43
(6,137 Views)
