DASYLab
Analog Input Module Does Not Output correct value
I am using DasyLab V10.0.1 with Windows XP SP3. I am using a MCC PCI-DAS6013 analog card attached to an analog input module. I can see the voltage for channel 1 at 5.4v when I open the properties windows for the module but when I connect a digital meter to that module it does not output that voltage value. It shows a value like 253.20. Any ideas on what I may be doing wrong?
(6,981 Views)
millswj,
Thank you for posting on the NI Forums. Is it possible that the module is not working properly? I can't really provide any insight into what could be wrong with the hardware since it is a third-party device and I have no experience with it. You mention your DMM shows 253.20, is that in mV?  There is also another resource for help with Dasylab, DASYTEC's online technical support (http://www.dasylab.com/content/mydasylab.php?action=start). Thanks!
Aaron W.
(6,973 Views)
