DASYLab
Accessing Sequence Generator bit settings
Is there a way to remotely access and change the bit settings internal to the sequence generator?
We want to make a excel based test editor. I can set the analog and time commands via variables, but cannot find a path to the bits.
I am using Dasylab version 13.
There's never time to do it right, but there's always time to do it over!
(6,054 Views)
Are you talking about the bits that can be generated by each step?
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(6,051 Views)
I believe that you are correct... that the bits are fixed in the program, so that they cannot be global variables.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,049 Views)
