DASYLab
ADAM 4019+
I have the dasylab 9 and I want to install the adam 4019+ from advantech
Does anyone know how to do this?
please tell it as simle as you can because I am new to this..
thank you in advance.
Message 1 of 13
(11,338 Views)
Did you get my e-mail?
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
Message 2 of 13
(11,337 Views)
Dear greek,
I have checked the current DASYLab 11.0.1 Advantech ADAM driver. We support here only the devices from Screenshot. A 4019+ is not yet supported. I found on Advantech homepage http://www.advantech.de/products/search.aspx?keyword=4019+ the message "... ADAM-4019+ provides not only ADAM ASCII commands, but also the Modbus/RTU protocol for satisfying different application demands ..." There is an workaround that you use the device based on our DASYLab 11.x Modbus module?
MHa
20069iBFF7C3A61EA9EE69
Message 3 of 13
(11,324 Views)
Thank you very much
So I can't use Dasylab 9.0?
I am trying all these days and I can't fix it
Modbus modules can't connect with the adams
and I don't know why?
Message 4 of 13
(11,191 Views)
Dear greek,
for an Modbus support you need DASYLab 11.0.x.
MHa
Message 5 of 13
(11,187 Views)
I don't know why they cannot connect. I don't have any modules here to test with. I reviewed the ADAM manual, and they don't indicate the data type for the registers. DASYLab V9 only supports unsigned and signed integer data types.
the V11 modbus is more flexible. Try downloading the evaluation from www.dasylab.com, and then the service pack. See if the V11 modbus module works.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 6 of 13
(11,186 Views)
I am sending you the printscreens of Utility and of the modbus input.
I use modbus protocol
but I can't achieve the communication between Modbus Input Modul and Adams
please take a look
Utility
http://img706.imageshack.us/i/utilityprintscreen1.png/
http://img832.imageshack.us/i/utilityprintscreen2.png/
Dasylab ( in to Module)
http://img193.imageshack.us/img193/3825/dasylabprintscreen1.png
setup
http://img17.imageshack.us/i/dasylabprintscreen2.png/
Message 7 of 13
(11,173 Views)
greek,
the attachments tell me that you don't use DASYLab 11.0.x. Our last posts tell you that is not useful. Between DASYLab 9.x ... 10.x and now 11.x are a lot of important bugfixes for general modbus handling. You can only use a current DASYLab 11.0.x for this job! DASYLab 9.x is not longer supported from NI.
MHa
Message 8 of 13
(11,167 Views)
Well I installed the Dasylab 11.0 but I still have a problem with it.
I can't achieve the communication between ADAMS and DASYLAB with modbus
I am sending you the new printscreens
What I am doing wrong?
Should I do anything else?
Message 9 of 13
(11,093 Views)
Message 10 of 13
(11,092 Views)
