DAQExpress
Taking inputs from two sources, both are the simulated device supplied with DAQExpress
I was using DAQExpress to simulate some hardware for a project that I'd need to monitor. Simple things like voltage and current. I've tried this with both DAQ Reads in the same while loop and separate loops. The program quits saying the resource is already allocated.
One source comes from the simulated port 0 (SimDev1/a0) and the second from port 1 (SimDev1/a1.) Does DAQExpress support going at only one device of this type?
What did I miss? Haven't yet run across something looking at some of the other boards on LabView or NXG.
(3,993 Views)
fuzzy601,
Can you attach some screenshots of your task?
tuco100s
(3,954 Views)
Attached is a screenshot of the code and the error. Double checked that both simulated devices were separate channels. Thanks.
(3,944 Views)
