DAQExpress
DAQmx installation error
When i'm opening DAQExpress 2.0 I get the following error message,ErrorDAQExpress.jpg
Anybody knows a solution?
Kind regards,
Dries
(7,841 Views)
Hi Dries,
Having a look at the error message it looks like there are a few steps to go through to troubleshoot this.
1 - Please fully reboot your computer and try opening DAQExpress.
2 - If this doesn't work please open up NI Package Manager and go to the "Installed" section, find DAQmx and uninstall. Once it has uninstalled please reboot and go back to NI Package Manager and install the latest version of DAQmx.
3 - If this doesn't work I would recommend uninstalling and reinstalling DAQExpress 2.0
If you are still encountering problems after this please let me know.
Good luck!
Alastair
(7,815 Views)
Thx for the answer. Unfortunately it didnt help.
I've tried the installation on an other PC, that worked.
So i think i've to remaster my PC.
(7,811 Views)
So remastering was the only way.
(7,801 Views)
Hello.  I am having the same problem.  Loaded the disk that came with a USB6001 DAQ and have had nothing but trouble.  Just tried it on the fourth laptop and I'm spent.  Windows 7 machines and now a very fresh windows 8 machine.  Software loads.  I run all the updates it asks me too one at a time with reboots after each one but nothing helps.  DAQExpress comes up as if loading and then gives the exact same error as above.  Have tried uninstalling and reinstalling many times on too many machines now.  All windows are Pro versions.  Not related to windows firewall as I have checked that.  I also have been reading here and have noticed there is not a "Package manager" anywhere to be found with these installs.  We have VI Package managers on other machines running NI software but not showing up in these downloads. Could the disk be corrupt?  Thanks in advance for any help.
Rich
(7,736 Views)
Since i had my laptop completedly re-installed, i had no problems anymore.
Dries
(7,716 Views)
After reinstallation of both DAQmx and DAQ Express, the issue remains.
Reimaging resolving the issue implies this is a registry issue, but reimaging is not an option for me.
Will someone with a working DAQ Express export the National Instruments registry entries?  I could then painstakingly go through them to determine where the issue resides.
Is there another resolution?
Note:  I have tried this method as well: https://forums.ni.com/t5/DAQExpress/DAQExpress-Installation-Problem/m-p/4062360/highlight/false#M285
(5,226 Views)
