DAQExpress
CVI and DAQmx error
I have an appliction which was written in CVI and a USB-6001 connected.
I used the THD example code of CVI do write very similar code.
On my computer the code runs well, but on different computers (only running the exe file and USB-6001, without CVI installed)  the application gives an error:
Error: DAQmx disconnected or no enough memory
The drivers in NI Max on the computers are identical 17.0
The computer that cant run the app has 16GB memory and the USB-6001 is connected.
Could you advise?
(4,436 Views)
Have you seen this knowledge base article regarding similar errors?
Understanding and Avoiding NI-DAQmx Overwrite and Overflow Errors
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAraSAG
What is your application doing? What is connected to the hardware?
Anson K
Applications Engineering
(4,413 Views)
I updated the driver of USB-6001 and it solved the problem.
(4,404 Views)
