Problem Statement: Both pushbutton switches are normally open. Consider this scenario: (1) Begin with both switches open, (2) close switch S1 long enough to charge the capacitor to its initial voltage of 5 volts and then open switch S1 again, and then (3) close switch S2 for a long time beginning at time t = 0. As the capacitor discharges vC(t) passes through two voltages of interest: 90% of its initial value and 10% of its initial value. Determine the time interval between the 90% and 10% voltages of vC(t).
Use jumper wires if you do not have pushbutton switches available
Make certain to use proper polarity for the electrolytic capacitor
Display the capacitor voltage vC(t) with the NI ELVISmx oscilloscope
Use the cursors to measure the time difference between the 90% and 10% voltages
Follow along with the video clip below to confirm correct operation of your measurement setup and to learn recommended procedures to operate the oscilloscope for a suitable display:
Comparison:
Report percentage difference between calculated value and corresponding measured value
Include screenshots of the oscilloscope display with cursors showing the measured time difference
