Curriculum and Labs for Engineering Education
Unit 4 - DAQ: Lesson 1
Introduction
In this lesson we are going to discuss Data Acquisition, commonly refered to as DAQ.
We will do our data acquisition using the DAQ Assistant Express VI. The DAQ Assistant provides a user interface to assist with DAQ configuration. Through this interface, all required data acquisition parameters can be conveniently setup using a wizard.
Lessons Video
Example Snippet
Practice Problem
Procedure: Create the required VI(s) to achieve the following tasks.
Requirement:
  1. Write data to one channel of the MyDAQ audio out (Hint: use the function generator found in the signal processing palette)
  2. Modify the program so that data is written to both the audio out channels (Hint: use the build array function)
Practice Solution
Next Step
Unit 4 - DAQ: Lesson 2
Comments
balticsea
Member
Member
on
nice,
