Counter/Timer
watch dog timer control
I have a panel_PC from advantech with xp professional. I am trying to figur out how to program the watch dog timer using labview 7.1.
Advantech listed up a programming example in basic. What is the easiest way to solve this problem. Can I implement basic into labview or
is it possible to read/write to I/O port 443 (hex) directly?
In advance Thanks.
Tor Ivan Karlsen
Appendix A Programming the Watchdog
Timer
A.1 Supported input timing modes
In order to program the watchdog timer, you must write a program which
writes I/O port address 443 (hex). The output data is a time interval value.
The value range is from 01 to 3E (hex), and the related time interval is 1
second to 62 seconds.
Data Time Interval
01 1 sec.
02 2 sec.
3E 62 sec.
After data entry, your program must refresh the watchdog timer by rewriting
the I/O port 443 (hex) while simultaneously setting it. To disable the
watchdog timer, your program must read I/O port 443 (hex).
The following example shows how to program the watchdog timer in
BASIC.
10
REM Watchdog timer example program
20 OUT &H443, data
REM Start and restart the watchdog
30 GOSUB 1000
REM Your application task #1
40 OUT &H443, data
REM Reset the timer
50 GOSUB 2000
REM Your application task #2
60 OUT &H443, data
REM Reset the timer
70 X=INP (&H443)
REM Disable the watchdog timer
80 END
1000
REM Subroutine #1, your application task
1070 RETURN
2000
REM Subroutine #2, your application task
2090 RETURN
TIK
(3,995 Views)
Attached is a demonstration of how the BASIC code might be implemented in Labview 7.1
Please note that this may (read probably) not be the ideal solution for your application or be the best way to implement such a system in Labview, however the principle is clear and as such you shoud be able to understand the process; which was the object of the demonstration code.
Possibly a better way to implement a watch dog system in Labview would be to use the Timed Loop function.
Sorry I don't have your hardware, so I am not in a postion to test the software with the hardware. Thus please feedback if the software works.
(3,973 Views)
