Counter/Timer
using internal clock
Hi
can you use an internal clock to controle a while loop. This is for taking measures in a period of time. The measures are random so i can't use a counter that counts the iterations, the iterations are random in time.
kind regards
(6,435 Views)
Hello Koen,
Can you define the targets you are working on and the internal clocks you would like to use?
For example:
- Are you using a Windows or an RT Target?
- Are you using a DAQ device or not?
If yes, which one?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(6,412 Views)
Hi ThiCop
I already found a solution for my problem.
Thanks for your reply
kind regards
Koen D'Hulster
(6,408 Views)
Hello Koen,
Can you mark it as resolved?
Kind Regards,
(6,406 Views)
