Counter/Timer
trouble using the counter on PCI 6025E
I am facing a problem with the counter on PCI 6025E. I am trying to count the number of pulses generated by the shaft encoder mounted on the shaft of a motor. I am using a channel from the shaft encoder to count the pulses and generate the line state. So, I have wired the channel to pins 25[line state]and 47[counter]on SCB-100. In my application I am using the count events/time vi from DAQ palette. Every time I run my application I have been getting the error NI 10001 saying that the ordering of the strings is not as expected.
(3,273 Views)
The Count Events & Time.vi is typically used with older counter hardware such as the 9513 chip. Your E Series card (6025E) uses a DAQ-STC chip. The best way to count your edges is to open up the example "Count Edges(DAQ-STC).vi which can be found by selecting Help>>Find Examples... and you will find it under the DAQ Counter examples as an DAQ-STC example. Hope that helps.
Ron
(3,273 Views)
