Counter/Timer
speed of incremental encoder
Hello!
I am using NI PCI -6251 and SCB-68 E SERIES DEVICES and LabVIEW 8.6.1 and have got incremental encoder which have A, B , Z signals.
I want to measure speed with DAQ. I used DAQ assistant (counter for measuring angular position) with 3 inputs
A signal (PFI 8)=37
B signal (PFI 10)=45
Z signal (PFI 9)=3
From DAQ assistant I get angle in radians or degrees or ticks.
I want to know how if DAQ assistant have some setting or .vi to measure speed with.
Or which will be the best way of measuring speed in Labview.
I also want to know how to get settings from DAQ assistant from the block in indicator.
Thank you for your answers.
(6,321 Views)
Hi DODI,
If you are looking for the best ways to implement some operation with your M Series DAQ, then I would suggest M Series User Manual. On page 7-6 (112 in pdf) you can find for example one possible use of counter input - period measurement. In fact it is what you need to do - because to measure speed, you need to know the time between 2 pulses, or by other words you need to know how many pulses of known timebase occure. You also need to know the distance obviously - which shold be simple, as when you use incremental encoder, then you know how many pulses you get per 360deg (which means you know how many deg you have between 2 following pulses).
This means, that you can get speed by dividing distance (known from your encoder) with time (known timebase frequency * number of pulses).
I hope you didn't get lost Smiley Wink
Unfortunately I don't understand the last question of yours: "I also want to know how to get settings from DAQ assistant from the block in indicator." Could you maybe clarify what you need here?
regards,
Stefo
(6,296 Views)
