Counter/Timer
retriggered single pulse
I am using NI-DAQmx C/C++ API. How can I set up a counter to produce a retriggerable single pulse? That is, I need to trigger an output pulse, and while the pulse is being generated, if a new trigger comes in, it resets the counter so that the pulse timing is extended.
Is that what the DAQmxSetStartTrigRetriggerable property does? I'm guessing that the ability to do this depends on the hardware being used?
Thanks!
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(6,770 Views)
No, in DAQmx a "retriggerable" pulse is one that re-arms once it has finished outputting.  Any trigger that occurs while the pulse is still being generated would be ignored.
What hardware are you using?
Best Regards,
John Passiak
(6,755 Views)
OK, thanks John. I've asked my customer what device he's using.
The need is a replacement for the (ancient) NI-DAQ API GPCTR_Set_Aplication() with ND_RETRIG_PULSE_GNR with something equivalent in NI-DAQmx.
John Weeks
WaveMetrics, Inc.
Fax (503) 620-6754
www.wavemetrics.com
(6,749 Views)
He's using a PCIe-6251; previously he used a PCI-MIO-16E-4 under the old NI-DAQ.
John Weeks
WaveMetrics, Inc.
Fax (503) 620-6754
www.wavemetrics.com
(6,747 Views)
Accepted by topic author WM_John_Weeks
I'm glad you clarified.  ND_RETRIG_PULSE_GNR does not extend the pulse timing if an additional trigger is received during generation.  From the NI-DAQ Function Reference Manual:
ND_RETRIG_PULSE_GNR:  ... Any gate transitions received during the pulse generation are ignored.
With this in mind, DAQmxSetStartTrigRetriggerable is in fact what you would want to use to get the same behavior in DAQmx.
Best Regards,
John Passiak
(6,715 Views)
Thanks for the link to the (ancient) documentation- it's been a long time since I did anything with the Traditional NI-DAQ.
I've added an option to my NI-DAQmx code to set the retriggerable option; I trust my customer will be happy.
Again, Thanks!!!
John Weeks
WaveMetrics, Inc.
Fax (503) 620-6754
www.wavemetrics.com
(6,703 Views)
