Counter/Timer
"Is it somehow possible to route the signal from a quadrature encoder in the "X4"- mode (4 times as often as channel A)to the RTSI-bus and use it so as a external clock?"
"I would like to take a quadrature encoder as an external clock. The good thing at a 3 channel quadratuer encoder is that I can use it in the "X4"-mode which means that the resolution is four times better than compared if you take just one channel (i.e. channel A).
My problem now is that I am not possible to route the "X4" signal to the RTSI bus, so that I am possible to use it as an external clock for an AI-data aquisition.
Is it possible to route this fourtimes faster signal than channel A would be to the RTSI bus?
I am using a PCI-6602 (master) and a PCI MIO 16E-1 card (slave)"
Message 1 of 1
(3,290 Views)
