Counter/Timer
pxi 6220 redefining terminal routes
In MAX explorer, the pxi 6220 routes tab shows a direct route from PFI6 to the counter 1 gate (ctr 1 to be used for low freq counter) and an indirect route through counter 1 to PFI 4.  But from the terminal diagram for the card, it looks like PFI 4 IS the counter 1 gate.
However, in LabVIEW terminal rerouting VI, I can select PFI 6 as the source and PFI 4 as the destination (there is no option to select counter 1 input as destination), but the counter does not appear to be counting.  At the moment the input on PFI 6 is a "TTL" level square wave, but I don't get any counts.
Does anyone have any experience with this...any suggestions on what to try to determine where the problem is?
Best Regards,
Chris
(4,438 Views)
Hi Chris,
To configure the input terminal of your counter to be a PFI line other than the default (PFI4 is the gate of CTR1 by default), you can simply use the CI.Freq.Term property node. To do this, place a DAQmx Channel Property Node down after creating the counter task, and navigate to Counter Input » Frequency » Input Terminal. You can then specify which PFI line to use as the input (for frequency measurement, the input is the gate of the counter). I have also attached a screenshot of what this looks like in LabVIEW. Hope this helps,
Daniel S.
(4,423 Views)
Hi Daniel,
Thanks for the ealier post...sorry it took me a while to get back to it.
The channel property node that only contains "Analog Input" and "General Properties"; no counter or digital properties.  I guess that's why I couldn't find the correct property...it isn't there!
I am trying to attach the code-of-interest to this message.  Please help.
By the way, I'm actually using a PXI-6221, not a PXI-6220.
Thanks in advance,
Chris
(4,388 Views)
Hi Chris,
If you are unable to see properties in your property node, I would first check to see if you are filtering the properties according to the devices in your system. There is a KnowledgeBase article outlining the property filtering which can be found here.
Also, if you right-click the section of the property node where the property is displayed, you should see a selection at the bottom titled “Select Property…” If you click this, a browser should appear with all the properties of DAQmx Channel.
If you are unable to select the property by right-clicking on the property node, you can also navigate to View » Class Browser and select the DAQmx object library and DAQmx Channel class. Hope this helps,
Daniel S.
(4,362 Views)
Daniel,
Thanks for the help; my problem has been solved.
The PXI chassis that I'm working with contains two 4472B cards (analog inputs only) and one PXI-6221.  I had to right click the channel property node, select the "Select Filter..." option, and then check the PXI-6221 in the "Show Attributes for Selected Devices".  Initially, both 4472B cards were selected but the PXI-6221 was not.
It works very well now.
Best Regards,
Chris Hassan
(4,356 Views)
