Counter/Timer
pulse width measurement for dummies
I  wish to do a pulse width measurement but I am unable to do so.  I have a PCI-6259 DAQ.  I am using counter 0.
In the current scenario I have a device connected to the gate terminal of the DAQ counter (PFI 9 for the PCI-6259).  When I send a command to this device via a RS-232 it will output a pulse of approximately 100us.  I wish to do a measurement of this pulse.  There are no other connections between the counter and this device other than ground.
When I run the example vi "Meas Pulse Width.vi" I get an error:
Error - 200474 occurred at DAQmx Read
(Counter DBL 1 Chan 1 Saml).vi:2
Possible reason(s):
Measurements: Specified operation did not complete, because the specified timeout expired.
Task name: _unnamedTask<0>
I assume that this means that it did not find any rising or falling edges in the specified timeout (20secs).  I know that a pulse has occured as I can measure it on an oscilloscope.
What have not done in my setup to make this measurement work?  I am sure it is really simple.
Ben
(4,364 Views)
Hi Ben,
Have you verified the following.
1. The ground of the device is connected to the PCI 6259's DGND.
2. The pulse that is being generated is of TTL level.
BR
(4,342 Views)
That's it!  There was an electrical disconnection between the counter and the device.
Thanks heaps,
Ben
(4,327 Views)
