Counter/Timer
output one voltage at every coming external clock rising edge
Hi,all.
    I wrote the attached code to output voltages triggered by an external clock.The external clock is about 1 Hz.For examle,I want to output 256 different voltages and change the voltage value when a new coming rising edge is ditected.
    The problem is when I run the code it says there is no data in the output buffer.
    Can anyone help me out with this puzzle?
(3,403 Views)
Have a look at the examples that ships with LabVIEW.
LV menu >> Help >> Find Examples... >> Hardware Input and Output >> DAQmx >> Analog Generation >> Voltage
(3,398 Views)
