Counter/Timer
ni6210 sample rate and sample per loop, task time
the sample rate set as 500Hz, sample per loop 500, cycle 100. I found the task was finished in 10 s instead of 100s.
what i dont understand is the time taken for this task. i suppose per loop takes 1s, 100 cycle should be 100s. furthermore, the input is 1kHz, however the counting is 0.
The VI scheme was attached.
(1,674 Views)
It probably would help to attach the VI instead of showing truncated pictures.
Lots of your code makes little sense (I am not a hardware guy, so I focus on the code logic only):
  • What is the size of the DATA array?
  • Why are you reshaping a 2D array (what size is it?) to another 2D array?
  • Why do you wire N of the FOR loop when autoindexing?
(1,644 Views)
Thanks "Altenbach",
The VI is attached. What I am trying to do is a counter application, input 1KHz or higher.
My questions is why the task time is not the "samples per loop" / "sample rate" * "number of cycles"
(1,607 Views)
