Counter/Timer
ni pci-6602 PFI pins and io register configuration
Hello, I am a new user of pci-6602 board and I am using matlab xPC.  I would like to use some PFI pins as digital output. I am not sure about what to do after configuration I/O Register. I configured I/O Register for inputs and outputs. Then which register should i use for sending data? SW Save register or else? And  do i have to do anything with  I/O Window registers? This not clear  in manual. I need  help in this issue.
(3,674 Views)
 Hi bckr,
 There is additional examples and documentation available with the NI Measurement Hardware Driver Development Kit. This includes example code and links to the documentation.
 I would advise posting any questions you have after that to the Driver Development Kit forums. This is where you will find people actively supporting register level programming with the 660x boards.
 It looks like you use GO_Load_A_Registers.writeGO_Load_A command to load the register after initializing the MITE board.
 If you have any further questions then please post them to the Driver Development Kit forum, that is where you will receive the best support.
 Have a great evening,
 MatthewW
(3,663 Views)
