Counter/Timer
newbie needs help on Quad encoder for cRIO 9421
When using PCI 4451/4452, we can use the GPCTR0_UP_DOWN Signal and input this signal on the DIO6 pin; this general-purpose counter 0 counts down when the pin is at a logic low and counts up when it is at a logic high.
If we are now using cRIO 9421, how do we achieve both the count up and count down capability which can be easily done using DAQmx?
Thanks thanks!
-Mr Bing
(3,857 Views)
Mr. Bing,
You can do the UP/DOWN counting programatically. You can modify the examples in this folder for your application C:\Program Files\National Instruments\LabVIEW 7.1\examples\FPGA\Counters\Event Counters. To count UP you can increament as you get the events and to count DOWN you can intialize a numeric control and decreament the value as you get the events.
Ame G.
(3,842 Views)
OIC.. THANK YOU! Smiley Surprised
(3,835 Views)
