Counter/Timer
make a xy graph with three data from cluster and tick count
Hi everyone.I have an issue with combining time counter and array of clusters to the xy graph. While three data are being collected, I want to write it into a xy graph seperately with the time counter. I also put my VI and png file. Please help.
(2,985 Views)
I also try the second way with using 'Build XY Graph' but still I couldn't get 3 data into the xy graph.  I put my second VI as well.But firstly I want to do it with array of cluster. Thanks.
(2,975 Views)
You need to build an array of the three clusters of XY data you want to plot, then pass that array data into your XY graph. You can use the build array function to do this. Here is an article that has a great example of what you are trying to achieve:
Multiplot XY Graph in LabVIEW
https://forums.ni.com/t5/Community-Example-Submissions/Multiplot-XY-Graph-in-LabVIEW/ta-p/3535615
Francine P.
Applications Engineering
(2,936 Views)
