11-16-2021 08:53 AM
i use a NI9401 to count a frequency of a signal
in the signal analysis i detect noise
i'de like to apply a lowpass filter (20hz) no my signal
11-16-2021 11:00 AM - edited 11-16-2021 11:03 AM
You *probably* only need the 2 properties DigFltrEnable and DigFltrMinPulseWidth. You'll need to read the manual for your cDAQ chassis because the appropriate pulse width setting will depend on what matters more: rejecting every frequency below 20 Hz or passing every frequency above 20 Hz.
As I recall, there's generally a factor of 2 between what's certain to pass and what's certain to be rejected. This arises due to the inevitable quantization that comes with discrete time operations.
-Kevin P
