Counter/Timer
how to stop Counter output when a condition mets from Digital or analog input in LV
Actually I acquired the pulses that I am sending to stepper motor. now the problem is to count the pulses so that I can connect the dial guage directly.
Try 1:
I tried pulse counting using Trigger vi's that counts the rising edge of each pulse and accumulates the running sum.
am I right or should I use any other efficient method for pulse counting.
Regards
Message 11 of 12
(650 Views)
Implemented properly, some kind of trigger condition detector could be used to post-process the analog pulse data and get a correct count of # pulses.  Odds are, the pulses are clean enough that a simpler thresholding method might be more efficient.  On the other hand, there's the *other* kind of efficiency that comes from using known-reliable trigger detection code instead of rolling & debugging your own custom algorithm.
Try your existing trigger code method and verify that it's accurate.  I'd venture it's probably efficient enough.
-Kevin P
Message 12 of 12
(646 Views)
