Counter/Timer
how to set up a edge counter on a 6221 daq
I am doing a pid fan speed project for college and have lutron anemometer vane. I'm getting a pulse train from the anemometer vane but can't count the pulses. I've tried setting it up on the daq assistant and tried the sample counters in labview with no luck. Any help would be appreciated.
(5,595 Views)
Hey James
The developer zone has a vast amount of examples on all sorts of things. This is quite a common task so I suggest you look on there. To get you started here is a link that is along the lines of what you asked.
https://decibel.ni.com/content/docs/DOC-15901
As an extra bit of advice, the forums tend to ignore students that are just looking for people to do it for them. If you are after help they are happy to give it but ask you have at least attempted it your self first. Posting your code generally demonstrates this willing.
Matthew Trott
National Instruments UK
www.ni.com/ask
(5,582 Views)
