Counter/Timer
how to measure frequency using daq 6009
HAI..
   Im using PFIO line to measure the frequency..i have attached my vi along with this..output is read approximately to the given input when i highlight the execution,but when i use run and run continuosly alone,am getting incorrect values..im totally confused..suggest some ideas..
another doubt, may i use analog port to measure the frequency of an oscillator?if so kindly help me to create a vi for this also..
(6,477 Views)
From your VI, one thing is clear, you are creating a task, but you are not clearing it. Please take a look at this example:http://decibel.ni.com/content/docs/DOC-8172
(6,463 Views)
thank you for the reply...let me check out with this..
(6,460 Views)
Hai sen..
                I found the problem..The problem is with the DAQ, The Counter port is not functioning and it is not Reading any Inputs..suggests anything for this problem if u Could..
(6,430 Views)
