Counter/Timer
help to check my project convert digital signal (count edge ) to RPM
and insert to colom N on table measurment..
but i doubt , my project is true or wrong..to convert digital signal ( pulse ) to RPM
i used count edge on USB DAQ 6008
Please help me to check in green border..
this is project i create
i copy at this article http://www.ni.com/example/13580/en/
Message 1 of 8
(6,794 Views)
Hello andriawan,
Have you tried running your code? What RPM outputs when you run it?
I'm just trying to clarify if this is a troubleshooting question for an error in LabVIEW or a math question for how to convert pulse to RPM. From what I can tell, you followed the example pretty closely except you did not divide the RPM by 1000 to get kRPM.
Lauren
Applications Engineering
Message 2 of 8
(6,769 Views)
I'm try , but error 20309 in pulse measurement vi. sad:
how solution about it ?
Message 3 of 8
(6,631 Views)
i use usb daq 6000
Message 4 of 8
(6,630 Views)
That error's description is as follows:
Analysis:  The amplitude of the waveform is zero, so the histogram method cannot be used.
In other words, you have no waveform captured.  Please post your actual VI so we can see all of the setups for the DAQ Assistant etc.
Message 5 of 8
(6,625 Views)
I don't know whether the DAQ Assistant settings are correct or not
Message 6 of 8
(6,612 Views)
Could you open up the DAQ Assistant and show us a screenshot of your settings?
Lauren
Message 7 of 8
(6,581 Views)
I already know where my mistake , My USB daq does not support reading frequency , because it appears the error .
is there any other way that can be added to my program to get the value of RPM ?
becouse i confused to setting looping and timing for counting and for my program...
Message 8 of 8
(6,570 Views)
