Counter/Timer
What ground to use for +5V
I have a NI6601 and I need to use the 5V output to drive an Optocoupler but I cant figure out what to use as ground. Can somebody please help me?
Per
(3,836 Views)
If you are referring to the PCI-6601 timer/counter card, any of the pins marked GND will work. They are all equivalently connected to the same point within the card.
(3,831 Views)
Sorry for being unclear Yes it is a PCI-6601.
I was confused by D GND and RG both seams to be at 0V, at first I thought that D GND was for the digital line and RG for the “power” line then I thought that D GND was ground for all and then I found some other references that just confused me so I decided to ask all you people.
If some one could explain what RG stands for I might be a little less confused 😉
Per
(3,825 Views)
Per the manual:
RG: reserved ground. Pins that are marked RG on the I/O connector are
no-connects if you use the SH6868-D1 shielded cable, while they are
ground pins if you use the R6868 unshielded ribbon cable.
You may also want to look at pg 4-22 of the manual if using the SH6868-D1 cable, it talks about twisted pairs and their respective grounds for high speed signals.
Good Luck!
(3,822 Views)
Thanks a lot that clears it up.
Can’t believe that I missed the D GND and RG thing it’s just right there when I look now. I did find the 4-22 page but it says nothing about the twisting for +5V so that is way I asked.
Per
(3,817 Views)
