Counter/Timer
VB.NET multi-cards displacement – analog input synchronization
I’m creating a VB.NET application which requires synchronization between analog inputs and a displacement measure (50000 pulses / meter) – displacement speed : 1m/s.
Used hardware
  • PCI 6528 (get/set digital I/O)
  • PCI 6220 (analog inputs)
  • PCI 6602 (displacement)
  • RTSI cable between 6528 and 6220
When the measurement is authorized (one input on 6528), I need acquire simultaneously, for a 10 meters displacement
  • time reference for each pulse
  • displacement
  • 2 analog inputs
To be continued …
Message 1 of 17
(6,130 Views)
VB.NET code structure
  • 1 task for analog inputs : “TskAnalogInputs”
    • First channel : Dev3/ai0, Differential, -10 V  +10 V
    • Second channel : Dev3/ai2, Differential, -10 V  +10 V
    • Clock : 1 sample on request
  • 1 task for displacement measurement : “TskDisplacement”
    • First channel : Dev1/ctr0 as “LinD”, TwoPulseCounting, 20 µm per count
  • 1 task for digital inputs : not implemented yet
User controls are autogenerated and instancied into the main form
To be continued …
Message 2 of 17
(6,113 Views)
The callback looks like
Public Sub OnMyDataReady(ByVal Sender as Object, ByVal e as UC_TskDisplacement.TaskEventArgs)
  ‘ Called when data are available
  ‘ Access analog data
  AI=TskAnalogInputs.Read()
  ‘ Store data into structure
  Str_Acq(idx).Time=environment.TickCount ‘ time (ms)
  Str_Acq(idx).Displacement=e.GetData(0)  ‘ displacement
  Str_Acq(idx).Analog0=AI(0) ‘ AI0
  Str_Acq(idx).Analog2=AI(1) ‘ AI2
  idx=idx+1  ‘ idx is a table index (integer)
End Sub
To be continued …
Message 3 of 17
(6,111 Views)
Str_Acquisition is a structure defined as :
‘ Acquisition informations
Private structure Str_Acq
  Dim Time as integer
  Dim Displacement as Double
  Dim Analog0 as double
  Dim Analog2 as double
End Structure
To be continued …
Message 4 of 17
(6,110 Views)
I’m able to separately :
  • take time reference of each pulse (in callback).
  • read the displacement (in callback)
  • read analog inputs synchronized with a counter (no displacement task runs)
but when trying to synchronize the whole, I loose counts (precision is divided by 50 – the smallest displacement measure I can see is 1 mm) !
I think the callback access counter and AI too slowly, but I don’t know how to change this to get the right precision (20 µm).
Can you help me ?
“Pas bavard”
Message 5 of 17
(6,109 Views)
I'm only a LabVIEW user and can't comment usefully about any of the VB.net code.  However, I DO think you should change the following:
Used hardware
I don't think the RTSI connection on the 6528 does you any good.  However, if you were to connect the 6220 (analog in) to the 6602 (displacement), then you could accomplish synchronization in hardware.
It sounds like your approach so far is to depend on software polling to take individual readings one at a time.  You'll be capable of much higher measurement rates if you instead let the data acq boards buffer your readings.
In LabVIEW this would be a pretty straightforward.  I don't know how one would approach it with VB.net.
-Kevin P.
Message 6 of 17
(6,100 Views)
Hi Kevin,
Thanks for the answer.
I will take a look on the RTSI cable.
I do that because I haven't found what I need on forums nor in DAQmx examples (I found for a simple counter, not displacement counters). I'm OK to use the board to buffer readings, but how can I do that with my application ? How can I route the counter signal to the analog board and get the counter value at the same time ?
Smiley Wink Yes, but I have no choice : VB.NET or nothing ...
"Pas bavard"
Message 7 of 17
(6,095 Views)
I changed the position of the RTSI cable,
Message 8 of 17
(6,073 Views)
I changed the position of the RTSI cable, but
Message 9 of 17
(6,073 Views)
I changed the position of the RTSI cable, but have
Message 10 of 17
(6,073 Views)
