Counter/Timer
Using Differential Encoder With USB-6221 and LabView
I want to connect the following: http://www.ifm-electronic.com/ifmde/web/dsfs!RB1015.html
with an USB-6221. Currently I have the connections as follows:
Ctr0 SRC, PFI 8: nothing
Ctr0 GATE, PFI 9: nothing
Ctr0 AUX, PFI 10: nothing
Ctr0 OUT, PFI 12: nothing
Ctr0 A, PFI 8: braun
Ctr0 Z, PFI 9: rot
Ctr0 B, PFI 10: grau
So the first question would be if this is the right connection scheme.
With this connection I am currently able to read the counter (edge-counting) in LabView with the DAQ-Assistant.
What I want to do now is measuring irregularities of the rotation (different times between two steps) and the direction of the rotation.
Unfortunately I do not really know how to do the former the right way and have no idea at all how to do the latter.
(4,568 Views)
6221 has single ended A, Z and B lines. In differential encoders you have A+/A-, B+/B- and Z+/Z-. So you will need a differential to single ended convertor to connect 6221.
"A VI inside a Class is worth hundreds in the bush"
യവന്‍ പുലിയാണു കേട്ടാ!!!
(4,546 Views)
