Counter/Timer
USB-6421 pulse width sensor class not appearing in flex logger
Recently ordered a USB-6421 along with a FlexLogger license to the newest version. The main purpose was because both the FlexLogger user manual and the USB-6421 user manual mention its ability to measure pulse widths through the counter channel. However, when I connect the USB-6421 to my PC, and connect through FlexLogger, the only options for physical measurements through the counter channels are Angular Position, Linear Position, or Pulse. When clicking Pulse, the only sensor class that appears is the Pulse counter and the only physical unit is Pulses. I have redownloaded the NI-DAQmx drivers, along with all the software that is included with a FlexLogger download. Any help would be very appreciated.
(216 Views)
While it is not officially confirmed and documented, pulse width measurement are only supported with NI-9361.
https://tmesystems.net/
(197 Views)
FlexLogger is designed for simplicity and no-code data logging. It often hides the low-level counter functions (like "Pulse Width Measurement," "Period," or "Frequency") that are directly available in the underlying NI-DAQmx driver (which you confirmed is installed) or in a programming environment like LabVIEW. For onboard counters on multifunction I/O devices (like your USB-6421), FlexLogger often presents only the high-level, common sensor types. The counter function you select in the Physical Measurement dropdown often dictates the available Sensor Class and Physical Unit.
(85 Views)
