Counter/Timer
Two channels needed with pulse delay. Do you know of a VI for this?
I want two channels, one with a given number of pulses of controlable length. On a second channel I want a controlable frequency during time the first channel pulse. I want to control the time after the pulse on the first channel goes high that the frequency on the second channel goes on.
(4,694 Views)
I'm a little confused as to exactly what you want. First, I'm going to assume that you are talking about TTL level signals, so the counters will be used. I'm also assuming that you have a DAQ card available to you. You can control output pulses on one counter, and set up a frequency on the other counter, but I'm unclear as to the relationship between the two.
Are my assumptions correct, and what is the relationship (in clearer terms)?
Mark
(4,694 Views)
