Counter/Timer
Timing Function
Hallo
Ich möchte nun im folgende VI die Digital OUTs in den Casestrukturen ganz rechts 3 Sek. aktiv lassen.
Im Moment schalten sie gleich wieder ab wenn sie aktiv waren.
Ich möchte Sie nicht nur kurzzeitig aktivieren , sondern diese 3 sek. lang aktiv lassen.
Wie kann ich das verwirklichen?
danke für eure Hilfe
dominik
(3,908 Views)
hi
Now I would leave in the following VI the Digitally OUTs in the Cases completely to the right of 3 sec. active. At the moment they switch off immediately again if they were active.
I would like to activate you not only for a short time, but let this to 3 sec. long active
How can I realize this?
thanks for your help
(3,904 Views)
Here is a little example that works with similar functions as you use in your vi. Currently it needs an initialization period of 3 seconds until you can use it. This might be easily improved if your applications requires other behavior than that.
Jochen Klier
National Instruments Germany
(3,882 Views)
