Counter/Timer
Timer during operation
During a frame of a sequence, our network is accessed and a file opened or created. This takes about 7 seconds before moving on to the next frame of the sequence. I want to display a changing indicator on the front panel during this delay. Any ideas?
(4,208 Views)
Hello Ralph,
Basically, you want a loop inside of the same sequence step as your delay. This loop will update the indicator on the front panel and terminate when the slow operation completes. The termination is handled by a local variable that can be written after the slow operation using a sequence or by a dependence on an output of the slow operation.
I've attached a simple example with a progress bar. It looks better in LabVIEW 7, but I've also included a 6.1 version; let me know if you need a different version. The local variable is a simple stop button; I would hide this control on the front panel for actual use, but left it visible to make clearer how I implemented it.
Let me know if you have any questions or if I can be of further
assistance.
Have a good day,
Kyle Bryson
(4,208 Views)
Thank you Kyle but I have LabVIEW 5.1 Could you send a 5.1 version?
Ralph
(4,208 Views)
Sure, Ralph. Try this one.
Kyle Bryson
(4,208 Views)
